Hello! I’m preping to install our new White Series switches. Several of the places we plan to install them are three ways. I had been hoping to use some of our existing dumb switches as the secondary switches in the three way, but I’ve noticed that some of the switches I’d like to leave as is are the first switch in the series. Is there any way I can do this using an existing switch or would I have to get the Inovelli Aux Dummy switches?
If you have Romex, that will not work because flip flopping the Inovelli and dumb would require four conductors between the switches. If you have Romex, you only have three, ground excluded.
One of the other hand, if you have THHN in conduit and can run another conductor between the switches, you should be able to accomplish what you’re asking.
