I’ve got two blue 2-1 switches and two blue canopy modules bound to each other (1 switch to 1 module) and they were setup through Smartthings and working well. My Smartthings hub then crapped out the zigbee antenna and nothing zigbee connects to it anymore. I’m using the opportunity to switch to home assistant and was wondering if there was a way to setup the switches and modules in home assistant without factory resetting them so I don’t need to go through and re bind them to each other, etc.
Any advice is appreciated.
Thanks
