Unable to Dim LED Lights in 3-way Setup
Physical install went well with your switch in line box. I updated register 22 to multi-way with dumb/toggle switch. I had an issue with flashing lights, but set register 10 to Maximum Level 90 corrected this. I can now turn lights on/off with either switch. I have not been able to get the switch to change brightness. I have toggled register 52, Smart Bulb mode On then off again. Still no luck.
I am running:
  • Home Assistant: v2025.2.1
  • OS: OS14.2.
  • Z-Wave addon: Z-Wave JS UI v3.20.0
Your device was included as:
  • MFG: Inovelli
  • Product: 2-1 Dimmer
  • Product Code: VZW31-SN
  • Security: NONE
  • zwave+: 2 (zwave long range - does not show)
  • FW: v1.2.0
  • SDK: v7.18.1
Thought Security and Z-wave Long range should show, So I re-interviewed the node hoping some values were read incorrectly. Still no luck.
Any Ideas how to get the dimming function to work. Home assistant shows the change, but light level remains constant?
Should the device Have security enabled? How is this done?
Should Z-wave long range show up? How?
Thanks for the Assistance.
Check Parameter 158, Switch Mode. I’m pretty sure that the default is On/Off. Change it to Dimmer.
Thank You! That solved my issue.
