Unable to Pair Inovelli Blue Dimmer Switches
Unable to Pair Blue Switches to Hubitat
Hello -
I’m completely new to smart lights and bought some Inovelli Blue Dimmer switches and a Hubitat C8 Pro. Whatever I do, I can’t get the Hubitat to find my switches. I have tried 3 ways to get it to pair:
  1. Using factory reset. I am holding the config and top paddle down until the light turns red then letting go of config then top paddle. The light then flashes red but then goes dark. Instruction manual says there should be a blue pulsing after the red flashes, but that does not happen.
  2. Tapping the config button 3x seems to get the switch into pairing mode as the blue light starts pulsing, but Hubitat still seems unable to find the device.
  3. I’ve tried pulling the air gap as I’ve seen some people have success getting the switch into pairing mode after doing that, but the switch just shows a really dim blue light that does not pulse.
I have my Hubitat just a few feet away from my switches so distance is not an issue. I have the Zigbee using channel 25 with power level 8. Appreciate any guidance for this newbie!
Is this happening with all the switches, or have you tried only one?
Just to confirm, are you putting your Hubitat into Join mode by selected “Devices”, “Add Device”, “Zigbee”?
