I have used the instuctions below for setting up time of day dimming levels. I have found that the first time the command is sent after sitting off for awhile the switch performs the old command. The IDE says that everything is working fine, but it is not. I have set default (local) level at the switch to 3 during the hours of 6:30 am - 10:30 pm child (local) level default is 100. If you press switch at 7am after being off for some time it will turn on to 3. If you turn it off and on again it will then go to 100. Yes, it is backward of the instructions, but as it is unreliable I would rather a light come on dim, then blind the wife in the middle of the night. Is there another way to do this?
