Vzm35 on a fan with hi/low wires
This is a bit annoying but I purchased the blue fan canopy to replace the Sonoff iFan04 that I have now but can’t figure out how to wire it. The fan has a wire for fan hi and another for low and the Inovelli only has a single wire. I’m not satisfied with picking a speed and never being able to change it.
This fan is about 20 years old and I’ve had four different canopies controlling it, this is the first one that just won’t work, unless there’s a way to wire this properly.
So I figured I would look at a new fan, they aren’t terribly expensive so why not? Well they now have modular plugs instead of just straight wiring and they don’t tell you what wires do what.
Any suggestions before I put the iFan04 back on and throw the Inovelli in the garbage?
Is this the model you have?
This ended up being some really whacky wiring from the contractor where they were using reds and blues. It’s been years since I had to figure that out and had forgotten how silly it was. All working now.
