VZW31-SN Aux Switch Scene states
I have a brand new VZW31-SN which I have connected to a White Series aux switch. Enabling the Aux Switch Scene mode, I am seeing the distinct Central Scene 004-006 events from the aux switch working great! :grinning: :grinning: :grinning:
One small enhancement I wanted to request: I see the Central Scene values come through, but my zwave-js/home-assistant events aren’t being mapped to the typical event states: CentralSceneKeys. Instead, I only see the raw values 0, 3, 4 etc. It is easy enough to reverse engineer these, but it breaks some of my Home Assistant automations.
Looking at the device’s debug info in zwave-js, I see the main Scene 001-003 from the main switch have value to state mappings, e.g.:
      "id": "11-91-0-scene-002",
      "nodeId": 11,
      "toUpdate": false,
      "commandClass": 91,
      "commandClassName": "Central Scene",
      "endpoint": 0,
      "property": "scene",
      "propertyName": "scene",
      "propertyKey": "002",
      "propertyKeyName": "002",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 002",
      "stateless": false,
      "commandClassVersion": 3,
      "min": 0,
      "max": 255,
      "list": true,
      "states": [
          "text": "KeyPressed",
          "value": 0
          "text": "KeyReleased",
          "value": 1
          "text": "KeyHeldDown",
          "value": 2
          "text": "KeyPressed2x",
          "value": 3
          "text": "KeyPressed3x",
          "value": 4
          "text": "KeyPressed4x",
          "value": 5
          "text": "KeyPressed5x",
          "value": 6
However, when I look at Scene 004-006 for the Aux Switch Scenes, the states aren’t there, e.g.:
      "id": "11-91-0-scene-005",
      "nodeId": 11,
      "toUpdate": false,
      "commandClass": 91,
      "endpoint": 0,
      "propertyKey": "005",
      "propertyKeyName": "005",
      "type": "number",
      "readable": true,
      "writeable": false,
      "label": "Scene 005",
      "stateless": true,
      "min": 0,
      "max": 255,
      "list": false,
      "lastUpdate": 1689039910040
I am not sure where these states come from, but searching the zwave-js source, I suspect this is supplied from the device’s firmware? If yes, is it possible to add the value states on the aux switch scenes too?
I’m surprised this hasn’t been addressed yet. I’m finding the same issue with the Red mmWave switches VZW32-SN. The blueprint I use is broken for aux switches without this.
