I just installed this switch and associated it to HomeAssistant using Zwave JS without issue. Running firmware 1.02.
The issue I am having is that values for KwH, watts, and other sensors are not auto updating. The only way I can get them to update in HomeAssistant, is to manually do a “Refresh Values” from ZWave JS.
I have the report intervals set to 30 seconds and also the report thresholds set, but that doesn’t work either when the values change the set amount.
Everything else seems to work fine.
