VZW31-SN Red 2 in 1 not responding to dimming commands in Home Assistant
Hi folks, I recently started moving devices from Smart Things to Home Assistant. I just moved a VZW31-SN 2in1 Red dimmer switch. The device appears to have onboarded just fine, I’ve set the wiring type for 3way/dumb successfully and the switch is responding to on/off commands.
However, if I set the dimming level via Home Assistant there does not seem to be a response – the light levels do not change.
This was working fine in SmartThings.
I appreciate any tips on how this issue can be fixed.
Disregard – apparently there is a configuration setting that I don’t remember configurating setting between on/off and dimming mode. So all good!
