Associate Groups 3 & 4 (child switch is the non-load switch, parent is the load switch)
I see where I can do this in the Home Assistant Interface, for each smart switch I have a Groups 3 & 4 and can set a Target Node and Target Endpoint.
Parent (Load) dimmer (Hall-S1)
Group 3:
Target Node=?
Target Endpoint=?
Group 4:
Target Node=?
Target Endpoint=?
Child (non-load) Dimmer (Hall-S2)
Group 3:
Target Node=?
Target Endpoint=?
Group 4:
Target Node=?
Target Endpoint=?
An also:
Set Parameter 12 to 11 (On Child)
This is listed as the âAuto Off Timerâ, is that the intended Parameter to set to 11 is did something change?
For the VZW31-SN (which is the device you are using but not the device in the original thread) Parameter 59 should be set to 1 on one switch and 3 on the others.
For Parameter 59 ([21-112-0-59-1] Send Local Commands to Associated Devices) I have options 1 to enable and 2 to disable, I assume itâs 2?
I can only get the slave switch to control the master if they are both set to 1 (enabled), which makes sense because the slave switch needs to send in the local inputs commands to the master.
Hi, from your previous post you are trying to setup two switches right? The article I linked gives that scenario, but the screenshot I posted is similar to give you an idea (it is actually 3 switches in my setup - Switch1 â Switch2 â Switch3). Maybe just look at the article because it is probably less confusing.
P59 is actually presented a little different in Z-Wave JS. You can set the actual value if you scroll down to the bottom:
I donât recommend doing it that way. Z-Wave JS doesnât behave well when you change a parameter that it has broken out already. You actually end up with the broken out versions as well as the non-broken out version and the two donât stay in sync.
On the main switch (which has the load connected), you want both of those options for Parameter 59 to be âEnabledâ otherwise when you turn on the load from your hub, the secondary switch will not reflect the state.
