VZW31-SN Z-WAve association issue
I have two VZW31-SN switches in a virtual 3-way, using a Z-wave association. Local controls are correctly sent to the partner switch, but z-wave commands are not. Example: A tap on the paddle of either switch gets correctly relayed to the other switch, but an Alexa command does not - only the switch with the load responds. I have configured the switch that Alexa controls to forward both local and z-wave commands.
With the earlier firmware, 1.02 I think, this configuration worked as expected. I’m running 2.01 Beta at the moment. Is this a bug in the beta code?
