VZW32-SN dimmer indicator command class color
Hi,
Is there any way to set the color of the LED when using the indicator command class?
I’ve been playing with a VZW31-SN switch connected to Z-Wave JS UI and MQTT, and I want to use the indicator command class to trigger flashing lights on various events. I’m able via MQTT to send a Z-Wave indicator set command to set the on/off duration and count, and this does indeed make the bar blink as planned. However, it always blinks blue regardless of what I have set for colors of the LEDs via configuration parameters.
I’m aware I can set parameter 99 to trigger animations, but like being able to directly control the flash speed and duration over having a pattern.
  • Jw
No, it’s not. The switch only has support for identification via that command class. All of the custom lighting effects have to be controlled via the configuration parameters for led effects.
