Are there instructions on how to setup 2 mmWave smart switches in a 3-way setup? I see the wiring instructions but after it’s wired, will it automatically work as a 3-way or do I need to make a group for the two switches to work together? Also in the parameters, do I set it as a 3-way with aux (even though it’s not really a true aux switch)? I found the wiring instructions so I’m good on that but wasn’t sure about the actually
You will need to use Zwave associations. There is a section in the manual that has links for Hubitat and SmartThings.
I’m pretty sure the primary switch should be configured as a 2-way and the other one with no load doesn’t matter.
Any luck in getting this working? I’m using home assistant - have spent many many many hours trying to get this functioning correctly
Current issue is that my load switch cuts the power to the light even if the remote switch sees me. Seems like remote switch isn’t sending a “still occupied, don’t turn off the light” message to the load switch
From what I’ve read, zwave doesn’t send state over the association - so I’d have to use my hub to drive presence and decouple the light on/off from the mmwave. My entire plan with purchasing these was to remove my automations and use just the intelligence on the switches
Yes, that’s correct.
