What Z-wave network is considered to be too "heavy"
Hi
I have about 32 devices Z-wave (21 Red 2in1 dimmers, some Zooz switches and motion sensors). I am using ATRIM 800 stick with HA Z-wave JS [zwave2mqtt], and recently I am having challenges to include new devices or heal network, update firmware. Especially with devices at a different from stick floor. Any recommendations?
Thanks
32 devices shouldn’t be too much for your mesh. I have 55 myself on my Hubitat C-8 hub and have no issues.
What can cause issues however are devices that are not paired properly. Those will cause what is typically called « ghosts » and must be removed ASAP. These are devices that didn’t pair correctly and because of this, other devices try routing through them but are not successful. They tend to cause issues on the Z-Wave mesh.
Unfortunately, I am not sure if they would cause an issue with your setup, how to see or remove them in that case. Hopefully, others in the community can chime in to help with that!
Are you using a USB extension cord? A 3ft or longer cord is recommended.
Yes, I am using extension cord (3 or 4 feet).
I did not have any issues before I exceeded 20 or so devices.
The communication is not an issue once devoice included to network, but inclusion recently is real pain (and firmware update) for remote devices
How I can check and fix it?
BTW, with Zigbee I have about 54 devices and no issues whatsoever (except the fact that I am waiting for 2.15 :slight_smile: )
Thanks
Are you using zwave-js-ui? If so, go to the addon. Any devices with a red sad face are dead. Click on the device and try to “Ping” it. If that doesn’t work you can click the blue hamburger and click on the purple “Advanced actions” button. Click a “Heal Network”. That will try to rebuild the mesh.
Using
I do not see any “red faces” I cleaned it yesterday with
Last time I did “heal network” it took forever to perform operation
You can try healing the problematic nodes individually. If you go to the network, do you have any nodes with more than 2 hops? Maybe you have a dead spot in your network?
[quote=“vladimir.korobov, post:6, topic:14696, full:true”]Last time I did “heal network” it took forever to perform operation
[/quote]
Even though it takes a while, you want to heal the network anytime you do anything significant to it. Such as adding new devices. There’s a big difference when a node needs to make 4 hops vs it being able to do it with 1.
I also notice you have an 800 series stick. This is relatively new and there may be bugs in the stick’s firmware. The 700 series stick when launched was a complete disaster.
I’ve downloaded the latest firmware, but I can’t update
Used this link for instructions
found on Silicon Lab github
zwave_ncp_serial_api_controller_BRD4204D.gbl (127.7 KB)
But I am getting error massage:
What I am doing wrong?
I am also getting errors trying to update to 7.19.5, 7.20.3, as well as 7.21.1. Did you ever figure out why this stick won’t update?
not really. Moved to Zooz 800 stick with more recent FW. I still do not think it is possible to update FW, Silicon Lab did not fixed the issue (thr latest I heard, but I may be wrong)
I do not have issue now, but would love to know how to keep my stick updated with latest version
Zooz has update instructions on their site.
I did end up figuring this out, but still waiting on a solution.
There is an older version of this stick out there based on the 7.17.x firmware and Silicon Labs has stated in their firmware updates that it is not able to be upgraded without compiling custom firmware (due to a smaller required flash memory on these older devices is my understanding).
There is a newer version of the stick out there based on 7.18.x firmware that can be upgraded but as far as I can tell there is no way to know which stick each distributor has. Inovelli has reached out to another distributor that supposedly has these to find out more.
TLDR; It is not possible to update this stick from 7.17.x but if you already have 7.18.x+ you can.
