I received a White Series manual with my switch that was labelled as revision 2.0. However, when I look on White Series Dimmer Switch • Manual | Inovelli Help Center the linked pdf is v1.0.
Can we update that wiki to have the new version?
The website is up to date. If you take the time to read, it clearly says that the pdf may be out of date. The resource website will always be the most up to date for information. If you want a pdf just export the site as a pdf.
I read that before posting but it doesn’t apply because they already took the effort to make v2 of the pdf so swapping to that in the link would make sense.
Exporting the site as pdf does not result in something as concise and consistently formatted. It’s reasonable to be able to get a pdf of what came in the box.
