White 2-1 and Hubitat
Installed my first White 2-1 switch yesterday. I am using a homepod mini as a tbr and then connecting to hubitat. Is there an Inovelli specific driver for the White’s in Hubitat? If not, what device type should I use? @mamber @EricM_Inovelli
@Eric_Inovelli FYI - when I received my switches I was sent an email with links to setup guides, but most of the links including the Hubitat one are broken.
The generic matter drivers in Hubitat should work.
I tried that. I was hoping that there was a driver that would allow you to change the configuration options like you can on the Blue 2-1 switches. Doing it with button presses is painful.
Unfortunately that’s a limitation of the Matter spec currently. It doesn’t support configuring parameters from the hub.
You can see the full comparison of what’s supported between red / blue / white here: Red Series vs Blue Series vs White Series • Which is Best for You? | Inovelli Help Center
We have a beta driver that one of our community members created that supports most functionality. I think he was going to post it up as soon as he fixed a bug or two in it.
Awesome. I look forward to trying it out.
@Shadrach So most things are working in this great community supplied driver:
Hubitat-matterTools/Inovelli/VTM31SN at main · jvmahon/Hubitat-matterTools (github.com)
I think the only thing that is missing is scene control, but I have worked with the Hubitat devs and they will be releasing a Hubitat update that will fix a bug in “event subscriptions” (which is what is causing scenes to not work).
Thanks @jvm33 for the help on this and tons of other stuff!
Thanks a lot @jvm33 and @EricM_Inovelli the new driver is working great. I will be adding more Whites this week and the driver will make configuration super quick. i look forward to future updates. any chance you can add ramp rate to the list of parameters?
