White Dimmer Switch won’t dim
I have a white series dimmer that I did have hooked up to a dumb switch and it worked fine. I began adding switches, and changed the dumb switch to an Aux switch. Now it will not dim. It starts to dim very slightly but then goes to full bright. The only way it works is if I put it in on/off mode.
It is in Aux Switch mode
I have put it in dimmer mode when trying to dim
I have tried the quick button sequences and home assistant device attributes to put it in various modes.
Is this possibly a wiring problem? I wired a bunch of other ones and haven’t seen this in any but this one. Anyone have any ideas?
This topic was automatically closed after 75 days. New replies are no longer allowed.
