White Humidity Switch in HAOS
Hi, I decided to give the White Matter switch another go and it now connects to my HAOS system (though it’s been losing connection after some hours, topic for another thread).
I’m trying to setup a humidity automation and want to use the switches internal advanced timer. Right now I’m using the “Switch (Load Control)” entity but I’m not sure that’s the correct method, seems it just turns on the relay but does not simulate the multi tap to set the timer? I could be wrong but the button UP press seems to be just a sensor not a control?
