White On/Off Switches recognized as outlets
Is there a way to force the White Series On/Off switches to identify themselves as light switches when porting directly into Apple Home? All my dimmers are appropriately recognized as lights whereas it insists to label the On/Off switches as outlets
This is normal behavior for an On/Off switch, but iOS let’s you change the identification.
Tap the “gear” icon for the On/Off device, and under the “Rooms” setting you will see a “Display As” setting. The options there are “Fan”, “Light”, “Outlet.” Simply pick the one that works best.
