White Series Buzzing when powered on
I just installed my Inovelli White that I got way back from the pre-order (I know its been a while) but when powered on the switch makes quite a loud buzzing noise. It is the switch for 3 color phillips hue BR30 bulbs in directional recessed lighting fixtures.
Any ideas?
Pull the switch and check to ensure the conductors are firmly seated. When installing, the conductors go between the backing plate and the screw.
Did you test to determine which conductor is the line and which is the load?
Yep, the conductors are correct, the load is hot when the switch is off, and line is not. And the connections are firm between the screw and plate
Okay, so that wiring is NOT correct. The Line gets constant hot. The Load conductor is switched, so it will only be hot when the switch is on.
In a 2-way, the hot conductor goes to the Line terminal. Test with the conductors removed from the switch.
