White series dimmer and Aux switch
I have just installed an aux switch for a three way switch. The smart switch works fine, but the aux doesn’t work.
I’m using a white series dimmer.
I have:
- swapped the Smart switch with another one to be sure it wasn’t a switch problem
- swapped the aux switch to ensure it isn’t a aux switch problem
- factory reset the switch
- set the switch to dimmer + aux in smartthings and using the padel switch.
I’ve previously had a different smart switch and aux from another company in this location, so I’m confident that the wiring is correct.
I also installed another three way switch 3 feet away and it is working just fine.
I’m very confused
