good afternoon, all, I am setting up my 3rd Inovelli white series dimmer switch (single pole no neutral using as a dimmer) (all are in Apple Homekit). For this 3rd switch, I am trying to change the led bar color from the default blue when on and default blue when off. And set them both to green instead.
I am reading the Help section in the Inovelli website and trying to follow the video as well but all unsuccessfully thus far.
From what I read and see in the video, I need to hold down the config button until it turns ocean blue then blinks white and let go. then tap the config button 9x times, then us the up and down to set the color I want instead (green) then hold down config button again until it goes to ocean blue and blinking white again.
What happens for me when I initially hold down the config button it goes to ocean blue, then green, then yellow (never blinking white).
I am sure it is user error since I am still new to Inovelli, any help and time is appreciated.
thank you!
Jonathan
