White Series Dimmer Switch Firmware Changelog | VTM31-SN
@dudo @andrewk just preparing to send out the email to users about the update and will probably move it into production DCL early next week.
What about an update to the firmware of VTM35, the fan switch? That is my only problem switch right now and I don’t see any new firmware info.
VTM35 and VTM36 updates are currently in beta and probably won’t be official for several more weeks. If you want to try out the beta PM me.
Hey @EricM_Inovelli – I think in the other replies on this thread you might have missed my question here! Looking forward to the 1.1.6 production release, curious if you have any update on that.
@philip I thought I answered this somewhere, but 1.1.6 will likely sit in beta for quite a while. We likely won’t certify the next firmware for the VTM31 until after we finish working on the VTM35 and VTM36 update to matter 1.5.
Ah sorry, I might have missed that. Can I get on the 1.1.6 beta then? Please DM?
please DM
If you area using Home Assistant, VTM31-SN v 1.1.6r1 is available on the test-net dcl so you just have to activate “Enable test-net DCL usage” in the Matter Server configuration. Once you do this you will be able to update the switch via HA (will take 24-48 hrs to appear) without having to use SCP or SMB to move the file onto the HA server.
@EricM_Inovelli Could I get a copy of the V1.1.6r2 firmware? Manual min/max brightness control is something I’m been needing.
Sure, I did post a copy up on our file server:
Index of /firmware/VTM31-SN/Beta/1.1.6r2
The new matter server makes it super easy to install but let me know if you have any questions.
Awesome! Works great!
Posting revision 2 to testnet-dcl?
@CroVlado If you have HA it is really easy to upload the OTA file from the Matter Server UI. Once uploaded to the first device it becomes available to upload all other applicable devices from the normal “Update” panel in HA.
@andrewk I do love how easy the new Matter Server has made updating the firmware! @CroVlado I did also put it in testnet a few minutes ago so either should work shortly.
