White Series Dimmer (VTM31-SN) ignores brightness commands in HomeKit motion automations
The dimmer works normally for manual control, HomeKit slider control, and scheduled automations. But when triggered by a motion automation, it ignores the brightness value and turns on to the last brightness level instead of the level specified in the automation.
Details:
  • Model: VTM31-SN (Thread/Matter)
  • Mode: Dimmer Mode, Trailing Edge
  • Switch Delay: Off
  • Behavior:
    • Scheduled automations (e.g., “Set to 8% at 6:35 PM”) work correctly
    • Motion-triggered automations (“When motion detected, set to 2%”) instead turn the lights on to the previous brightness
    • Scenes do not resolve this
    • Default Level parameter does not affect automation behavior
Reproduction:
  1. Set lights to 40%
  2. Turn lights off
  3. Trigger a HomeKit motion automation set to 2%
  4. Lights turn on at 40% instead of 2%
Expected:
Motion automation should turn the lights on to the commanded brightness.
Actual:
Dimmer resumes last level and ignores the brightness value.
