White Series Dimmer (VTM31-SN) vs On/Off Switch (VTM30-SN) Details
Hi All,
I purchased five White Series Dimmers (VTM31-SN) and am very happy with them. However, I noted a few things:
If I wanted to pass a dimmer in on/off (simulated) mode through Home Assistant to Apple Homekit without dimming functionality, I had to do some Home Assistant voodoo.
Additionally, the White Series Dimmer (VTM31-SN) page says that the switch cannot be used for fans or with ballasts/transformers. Whereas the White Series On/Off switch (VTM30-SN) says that it can be.
For those two reasons, especially, I decided to wire the rest of my house with simple White Series On/Off Switches (VTM30-SN). Unfortunately, Inovelli accidentally sent me more dimmers. So, I have to ask:
  1. Will the On/Off Switches present differently in Home Assistant (and thus to Apple Home Kit via my bridge): Specifically, will VTM30-SN units appear as a simple light/switch without dimming capability? Or will it appear just like my existing dimmers?
  2. Can a dimmer be used with a fan/ballast/transformer when it is put into On/Off mode?
Aside from those two things, I think the only other concern is the humidity sensor on the On/Off model. But I won’t miss that.
If the Dimmer is safe with fans/ballast/transformers in On/Off mode, and the On/Off switches don’t appear any different to HA, I might consider just keeping the Dimmers and using them in On/Off.
Thanks for any details/clarifications!
–Brian
No, the on/off mode still uses the dimmer circuitry. So the dimmer is not rated for fan load regardless of the mode, unfortunately.
Not sure about the white series. But the blue on/off appear exactly like dimmers. I would expect the white to do the same. You can make a template entity in Home Assistant to convert the light to a switch entity and send that to Homekit.
To my knowledge, there is no way for the on/off switch’s LED bar to work like the dimmer switch showing the brightness level. It’s either on, off, or showing a notification.
It does show the brightness on the blue series with smart bulb mode. I assume the white series would do it too if it was bound to a thread bulb.
I just bound a VTM30 to a Matter bulb and it only turned the light on and off. Dimming did not work. Smart Bulb Mode was enabled and the Switch Mode is set to Dimmer+Single.
Did you put it in the Dimmer mode?
Yes. I said “Switch Mode is set to Dimmer+Single”.
This is just a WAG, but try setting the dimmer mode via a quick tap to confirm. I’m waiting on a response from Inovelli re this.
Answering my own question now that I have both dimmers and On/Off switches. The White Series On/Off do indeed appear as simple switches in Home Assistant and when passed through to Apple Homekit, they are simple On/Off there too (of course). So, there’s no tweaking necessary in either to get them to just be On/Off and no “slider” for dimmer in the control presented in the app(s).
This topic was automatically closed 14 hours after the last reply. New replies are no longer allowed.
