White Series Humidity Trouble Adding to HA
Hi All, second post here but still new to Inovelli. I have the humidity switch and initially tried to set it up on Alexa. Got it connected but was not reliable. I’ve been trying to get this connected to Home Assistant but it almost always gets stuck checking thread network connectivity. I have Eero running the border router. Anyone else have a working similar setup?
No one else is using the white series switch with HA?
You’ll probably have better luck on the Home Assistant forums or discord. Thread / Matter connectivity is hard to troubleshoot and can be very hit or miss from what I’ve seen depending on the border router.
There are other people using the white series with HA but I’ve not seen a post from anyone using Eero as the thread border router.
