White Series odd behavior in 2 way setup + dumb switch
When I toggle the light with the dumb switch, it causes odd behavior with the Inovelli White switch. When the lights turn off, the White switch turns off its LED bar, but I have to press “Up” twice to turn the lights on. As well, at random the lights will be set to about 15% instead of max brightness, even if they were at 100% last time. Here’s what its set to in home assistant.
The other one that I have in the kitchen in single pole mode also won’t make a clicking sound even if I have relay click on.
