Hello,
I bought the White Series (Thread/Matter) Smart Dimmer with the goal of using it in a room with 5 smart bulbs. I’m running Home Assistant and also have a bunch of Amazon devices that should be compatible, like the Echo Show 15.
I can’t get the switch connected following the instructions on the Inovelli website for configuring with Amazon Echo. White Series Dimmer Switch • Setup Instructions • Amazon Echo | Inovelli Help Center
In the Amazon app, it gets to the part where it asks me to “Connect device to a Thread Network” but the only network listed is under Other Networks called “NEST-PAN-4D58” and when I select that one it asks me for a key that I have no idea what it is. Is this the Thread network that would be created by my Echo Show 15?
I tried adding the switch directly to Home Assistant using the app but I had no luck there either. (I think I need a dongle for this method, that I don’t have) White Series Dimmer Switch • Setup Instructions • Home Assistant | Inovelli Help Center
Any ideas what I could be doing wrong?
