White switch manual buttons no longer work
I had successfully added actions to a white switch for double tap button one and two. Button 1 turns several lights on and 2 turns them off. It worked for a while. Yesterday I cut the power to the room and when restored the double press doesn’t work. When I test the double press in HomeKit they work. Looks like the physical switch stopped working for some reason
Any ideas are welcome
It’s unclear to me the extent of the issue. Does the switch not work at all? Or just multi-taps? If it’s the latter, I wonder if multi-tap turned off in the reboot. To re-enable it, hold the down button and then tap the config button 7 times until the LED bar turns yellow, then release. This will enable multi-taps at the switch. If the switch is not registering single taps either, you might need to reset it.
Any chance you reduced the button delay (switch press delay on the white)? If you get below 500ms, the button presses may not register.
Checked that. Also the bottom button works. Only the top is not
I switched from the Inovelli driver to the Hubitat supplied generic matter dimmer and it works fine. A driver issue?
Clarification. The Hubitat driver did not give me the error when turning on but it didn’t turn on the light
