Yet another 3 way Aux Neutral Wire help post
Also something that may help you identify line/load. Find the line coming into the first switch from the power panel. Verify with multimeter or voltage pen. It should be connected to the black screw labeled COM or common of the first switch in line. On the other 3 way switch, the load (light) will be connected to the black screw or COM connection. The other two wires will be your travelers between the two switches.
