I’m having exactly the same problem. I’ve tried every firmware update guide out there, and none will work through ZHA for me. I’ve got one switch on 2.15 (and five more of those to install), 22 on 2.14, and 3 on 2.08. Every one of them indicates that they’re up to date.
I’ve tried adding the firmware to the zigpy_ota directory as per the guide and got nothing. Tried renaming the firmware to VZM31-SN_2.15.ota to make sure the syntax matched exactly and got nothing. Made sure the file was the right size. Changed the true/false flag for inovelli_provider. Rebooted after every step–no luck. Tried forcing the update with ZHA Toolkit, tried forcing through the Manage Zigbee Device dialog…no luck.
At this point, I’m either really doing something wrong, or I’m running into a software configuration problem that I’m just not seeing. Just checked my HA version, and I’m current at 2024.2.2.
…so I’m definitely watching to see what others are doing, because I seem to be striking out.
