Looks like it updated:
State Variables
- driverDate : 2022-08-14
- model : VZM31-SN
- fwDate : 20221103
- fwVersion : 2.05
Good to hear. Just know 2.07 will be coming out soon so if you have a lot of switches to update, Iād hold off for a few days unless you need one of the 2.05 fixes.
ok have about 40 switches to update
After updating the switch, there is no effect using the Sengled bulbs. Turning on/off misses bulbs.
Just looked up my zigbee ID, this switch is effected as 9434. I looked them all up and out of 15 switches 7 are either 9434 or 385B.
Long way to go to get to Lutron reliability.
Ehhh the signal issue was an oversight by the manufacturer. There wouldāve been no way Inovelli couldāve caught that on their own without the help of the community.
Plus, at more than half the cost of the RA3, Iāll continue to select Inovelli. Iām sure some folks will say the RA3 is worth it, but with a house of over 60 switchesā¦.Iām gonna pass on that expense.
I ended ditching the Sengled bulbs, replacing them with hue ones. Just using the Hubitat ABC Controller instead of the zigbee bindings.
Firmware 2.08 was released on Hubitat that has bug fixes for groups, binding, etc. Might be worth a shot to see if it helps out.
Iām having the exact same issue, Sengled multicolor zigbee bulbs, Hubitat C7, and Blues. I only have one 9434 switch, so Iām ignoring that group for now.
In a group of four bulbs and a blue series, more times than not the at least one of the bulbs either doesnāt turn on, doesnāt turn off, or has an extreme lag. Switch is in smart bulb mode, and binding is configured as is a group. On the 20221105 driver and 2.08 firmware. ![]()
I could never get the Sengled bulbs to work reliably, the hues ones work perfect every time.
Correction: all 30 of my switches are 9343 or 385B, so Iāll wait for replacements to test again. ![]()
I made the mistake of buying ~40 Sengled bulbs. They obviously donāt even come close to conforming to the zigbee spec, theyāre all over the place and a general nightmare. They donāt seem to support binding at all and they will almost never route via anything except direct to the coordinator even if that means dropping from the network.
@Eric_Inovelli since you just went through Zigbee certification perhaps you would know ā is there a way to ask the Zigbee Alliance to prod Sengled to fix their bulb firmware or stop advertising them as Zigbee compliant?
