Using the new blue 2 in 1 in hubitat with zigbee sengled bulbs but having very similar problem I had with the older red series switches. When I turn the switch on some of the bulbs come on but not all (this is random), same with turning off.
I followed the setup guide for binding;
In hubitat devices:
For Dimmer Switch
258 set to dimmer
52 set to Smart Bulb
Using the Inovelli Dimmer 2-in-1 Blue Series VZM31-SN driver.
For Bulbs (4) Sengled Element Color Plus
Transition time (ASAP)
Enable color pre-staging
Enable level pre-staging
Reporting Interval 5s
Zigbee Binding
Bind this device: my blue dimmer
Use this endpoint (0x02) as stated in the guide
Bind power, level and color all enabled.
To these devices: my bulbs(4)
Use this endpoint (0x01) in the data part of the bulb
Bind enabled
Still not working, did try different sengled drivers. Problem still is some bulbs not turning on/off and when turning on, some bulbs arent at the same level as the rest.
Do the Reds and Blues just not work with Sengled bulbs ?
Since I can not get the Sengled bulbs to work with bindings, I grabbed some hue bulbs. Is it even possible to bind these with the switch through the hue hub and HE ? In HE under the bulb, the data field is blank since it is a Hue Bridge Integration.
No I believe if you want to bind switch to Hue bulbs, you have to include bulbs directly to Hubitat. If you want to use scenes then you can use the Hubitat to define the scenes to control the bulbs via Hue hub.
Binding Sengled E11-G13 bulb in a group with the switch worked for me before updating to 2.07. After 2.07 update this morning bindings just don’t work any more (actions are working really well, which is great). Tried resetting the switch, bulb, another bulb - tried individually and in a group in zigbee2mqtt.
