I’m losing track to be honest lol.
@EricM_Inovelli – which cycles are available on the 2-1 and Fan Switch for Fan Speeds?
I believe it does this, but let me check. If not, great idea!
@EricM_Inovelli can you confirm?
Yeah I need to go back and find all the spots I said this because we ended up creating a workaround. Technically, yes, the 2-1 is not rated for fans and the Fan Switch is not rated for lights, so we were in a predicament.
What we’re suggesting now is to just tie the line and load together at the line terminal of the switches to bypass the load terminal to stay in compliance. In other words, initially, we recommended wiring the line to the line terminal and the load to the load terminal of the switches and use Smart Bulb (or Fan) Mode on either switch (which still will work), but the compliance issue would be if someone turned off SBM, it would put the switch out of UL/ETL compliance. You’ll use either switch as a remote now (by tying the line/load together).
Idk why I didn’t think of that earlier as that’s how our old Fan/Light Switch used to work.
Great question – this is the one I have in all my bedrooms:
