Is it possible to use zigbee bindings to bind the “favorite switch” the small rectangular one to a zigbee bulb or do I have to use an automation at the controller? I figured out using ZHA how to bind the paddle switch but not the favorite switch.
I was hoping this would be possible even with a regular Blue switch, since latest firmware seems to open that door, but I couldn’t get it to work.
Perhaps binding endpoint 3 is reserved exclusively for use with the fan module? Dunno… But I’m curious to see what other responses pop up here.
Something I’m trying to do as well. Any luck here?
If you have the latest firmware you should have EP03 available after performing a factory reset.
Ok, thanks. I was using ep3 but it wasn’t working so it’s prob the sengled bulb not working with the binding. I’ll have to keep troubleshooting it.
Good to know it should work though.
Here’s my setup with Zigbee2mqtt: Can I bind EP3 / Config Button to Lights on the VZM31-SN? - #7 by rohan
It should be possible to replicate that config with ZHA but I haven’t used that in about 4 years so won’t be able to help if that’s what you’re using.
