@Eric_Inovelli @EricM_Inovelli, so both of the switches do the same the C-8 shows it has paired (get the green flash) I can control for about 5’ish seconds than switch (I get red flash) goes right back to pairing mode (blue light flashing) and no control. I do a re-pairing same cycle. I have reset both, paired both avoiding zigbee 3 repeaters, and exchanging keys in clear. I do have the one pair to C-7 and working.
@EricM_Inovelli .This error is in the middle of the logs I copied:
2023-10-15 11:52:51.952 AMdebuginmaster There was an error while calling zigbee.getEvent: read attr - raw: C8D30100001A05004208565A4D33352D534E, dni: C8D3, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33352D534E
Full log below:
742023-10-15 11:53:59.736 AMtraceinmaster MULTISTATE_OUTPUT_CLUSTER (cluster:0013 data:[95, D3, C8, A2, 73, 19, FE, FF, 27, 87, 04, 8E])
dev:40742023-10-15 11:53:59.731 AMdebuginmaster parse(catchall: 0000 0013 00 00 0040 00 C8D3 00 00 0000 00 00 95D3C8A27319FEFF2787048E)
dev:40742023-10-15 11:53:50.359 AMdebuginmaster off [he cmd 0xC8D3 0x01 6 0 {}, delay 333]
dev:40742023-10-15 11:53:50.356 AMinfoinmaster off()
dev:40742023-10-15 11:53:48.112 AMdebuginmaster on [he cmd 0xC8D3 0x01 6 1 {}, delay 333]
dev:40742023-10-15 11:53:48.108 AMinfoinmaster on()
dev:40742023-10-15 11:53:24.289 AMtraceinmaster MULTISTATE_OUTPUT_CLUSTER (cluster:0013 data:[93, D3, C8, A2, 73, 19, FE, FF, 27, 87, 04, 8E])
dev:40742023-10-15 11:53:24.285 AMdebuginmaster parse(catchall: 0000 0013 00 00 0040 00 C8D3 00 00 0000 00 00 93D3C8A27319FEFF2787048E)
dev:40742023-10-15 11:53:01.640 AMinfoinmaster Report: P258=1 (On/Off mode)
dev:40742023-10-15 11:53:01.637 AMtraceinmaster Private Cluster (cluster:FC31 attr:0102 value:01)
dev:40742023-10-15 11:53:01.633 AMdebuginmaster parse(read attr - raw: C8D301FC310A02011001, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0102, encoding: 10, command: 01, value: 01)
dev:40742023-10-15 11:52:58.295 AMtraceinmaster Private Cluster (cluster:FC31 data:[8D, 02, 01])
dev:40742023-10-15 11:52:58.292 AMdebuginmaster parse(catchall: 0104 FC31 01 01 0040 00 C8D3 00 01 122F 04 01 8D0201)
dev:40742023-10-15 11:52:57.967 AMinfoinmaster Report: P52=0 (SFM disabled)
dev:40742023-10-15 11:52:57.964 AMtraceinmaster Private Cluster (cluster:FC31 attr:0034 value:00)
dev:40742023-10-15 11:52:57.960 AMdebuginmaster parse(read attr - raw: C8D301FC310A34001000, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0034, encoding: 10, command: 01, value: 00)
dev:40742023-10-15 11:52:56.285 AMinfoinmaster Report: P258=1 (On/Off mode)
dev:40742023-10-15 11:52:56.282 AMtraceinmaster Private Cluster (cluster:FC31 attr:0102 value:01)
dev:40742023-10-15 11:52:56.279 AMdebuginmaster parse(read attr - raw: C8D301FC310A02011001, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0102, encoding: 10, command: 01, value: 01)
dev:40742023-10-15 11:52:55.949 AMinfoinmaster Report: P257=0 (Remote Control enabled)
dev:40742023-10-15 11:52:55.947 AMtraceinmaster Private Cluster (cluster:FC31 attr:0101 value:00)
dev:40742023-10-15 11:52:55.944 AMdebuginmaster parse(read attr - raw: C8D301FC310A01011000, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0101, encoding: 10, command: 01, value: 00)
dev:40742023-10-15 11:52:55.617 AMinfoinmaster Report: P52=0 (SFM disabled)
dev:40742023-10-15 11:52:55.614 AMtraceinmaster Private Cluster (cluster:FC31 attr:0034 value:00)
dev:40742023-10-15 11:52:55.610 AMdebuginmaster parse(read attr - raw: C8D301FC310A34001000, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0034, encoding: 10, command: 01, value: 00)
dev:40742023-10-15 11:52:55.281 AMinfoinmaster Report: P51=0 (Bindings)
dev:40742023-10-15 11:52:55.279 AMtraceinmaster Private Cluster (cluster:FC31 attr:0033 value:00)
dev:40742023-10-15 11:52:55.275 AMdebuginmaster parse(read attr - raw: C8D301FC310A33002000, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0033, encoding: 20, command: 01, value: 00)
dev:40742023-10-15 11:52:54.950 AMinfoinmaster Report: P33=0 (Overheat: False)
dev:40742023-10-15 11:52:54.948 AMtraceinmaster Private Cluster (cluster:FC31 attr:0021 value:00)
dev:40742023-10-15 11:52:54.944 AMdebuginmaster parse(read attr - raw: C8D301FC310A21001000, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0021, encoding: 10, command: 01, value: 00)
dev:40742023-10-15 11:52:54.676 AMtraceinmaster Private Cluster (cluster:FC31 data:[8D, 34, 00])
dev:40742023-10-15 11:52:54.672 AMdebuginmaster parse(catchall: 0104 FC31 01 01 0040 00 C8D3 00 01 122F 04 01 8D3400)
dev:40742023-10-15 11:52:54.641 AMinfoinmaster Report: P32=24 (Internal Temp: 75°F)
dev:40742023-10-15 11:52:54.617 AMtraceinmaster Private Cluster (cluster:FC31 attr:0020 value:18)
dev:40742023-10-15 11:52:54.612 AMdebuginmaster parse(read attr - raw: C8D301FC310A20002818, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0020, encoding: 28, command: 01, value: 18)
dev:40742023-10-15 11:52:54.344 AMinfoinmaster Report: P22=0 (No Aux)
dev:40742023-10-15 11:52:54.340 AMtraceinmaster Private Cluster (cluster:FC31 attr:0016 value:00)
dev:40742023-10-15 11:52:54.332 AMdebuginmaster parse(read attr - raw: C8D301FC310A16002000, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0016, encoding: 20, command: 01, value: 00)
dev:40742023-10-15 11:52:54.280 AMinfoinmaster Report: P22=0 (No Aux)
dev:40742023-10-15 11:52:54.278 AMtraceinmaster Private Cluster (cluster:FC31 attr:0016 value:00)
dev:40742023-10-15 11:52:54.274 AMdebuginmaster parse(read attr - raw: C8D301FC310A16002000, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0016, encoding: 20, command: 01, value: 00)
dev:40742023-10-15 11:52:54.008 AMtraceinmaster Private Cluster (cluster:FC31 data:[00])
dev:40742023-10-15 11:52:54.004 AMdebuginmaster parse(catchall: 0104 FC31 01 01 0040 00 C8D3 00 01 122F 04 01 00)
dev:40742023-10-15 11:52:53.953 AMinfoinmaster Report: P21=1 (Neutral)
dev:40742023-10-15 11:52:53.947 AMtraceinmaster Private Cluster (cluster:FC31 attr:0015 value:01)
dev:40742023-10-15 11:52:53.942 AMdebuginmaster parse(read attr - raw: C8D301FC310A15001001, dni: C8D3, endpoint: 01, cluster: FC31, size: 0A, attrId: 0015, encoding: 10, command: 01, value: 01)
dev:40742023-10-15 11:52:53.817 AMdebuginmaster Debug Logging will be disabled in 60 minutes
dev:40742023-10-15 11:52:53.779 AMinfoinmaster Info Logging will be disabled in 20 minutes
dev:40742023-10-15 11:52:53.778 AMdebuginmaster Debug logging Enabled
dev:40742023-10-15 11:52:53.775 AMtraceinmaster Trace logging Disabled
dev:40742023-10-15 11:52:53.774 AMinfoinmaster Info logging Enabled
dev:40742023-10-15 11:52:53.769 AMdebuginmaster setParameter [he wattr 0xC8D3 0x01 0xFC31 0x0102 0x20 {01} {122F}, delay 333, delay 3000, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:40742023-10-15 11:52:53.766 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:40742023-10-15 11:52:53.761 AMdebuginmaster setAttribute [he wattr 0xC8D3 0x01 0xFC31 0x0102 0x20 {01} {122F}, delay 333]
dev:40742023-10-15 11:52:53.757 AMdebuginmaster calculateSize(150)
dev:40742023-10-15 11:52:53.717 AMdebuginmaster setParameter [he wattr 0xC8D3 0x01 0xFC31 0x0034 0x20 {00} {122F}, delay 333, delay 3000, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:40742023-10-15 11:52:53.714 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:40742023-10-15 11:52:53.709 AMdebuginmaster setAttribute [he wattr 0xC8D3 0x01 0xFC31 0x0034 0x20 {00} {122F}, delay 333]
dev:40742023-10-15 11:52:53.705 AMdebuginmaster calculateSize(150)
dev:40742023-10-15 11:52:53.696 AMdebuginmaster setParameter [he wattr 0xC8D3 0x01 0xFC31 0x0016 0x20 {00} {122F}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:40742023-10-15 11:52:53.693 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:40742023-10-15 11:52:53.688 AMdebuginmaster setAttribute [he wattr 0xC8D3 0x01 0xFC31 0x0016 0x20 {00} {122F}, delay 333]
dev:40742023-10-15 11:52:53.684 AMdebuginmaster calculateSize(150)
dev:40742023-10-15 11:52:53.668 AMinfoinmaster updated()
dev:40742023-10-15 11:52:53.622 AMinfoinmaster Speed=off
dev:40742023-10-15 11:52:53.614 AMinfoinmaster Level=254 (100%)
dev:40742023-10-15 11:52:53.612 AMtraceinmaster LEVEL_CONTROL_CLUSTER (cluster:0008 attr:0000 value:FE)
dev:40742023-10-15 11:52:53.610 AMdebuginmaster zigbee.getEvent [name:level, value:99]
dev:40742023-10-15 11:52:53.602 AMdebuginmaster parse(read attr - raw: C8D30100080A000020FE, dni: C8D3, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE)
dev:40742023-10-15 11:52:53.271 AMinfoinmaster Power-On State=255 (Previous)
dev:40742023-10-15 11:52:53.269 AMtraceinmaster ON_OFF_CLUSTER (cluster:0006 attr:4003 value:FF)
dev:40742023-10-15 11:52:53.265 AMdebuginmaster parse(read attr - raw: C8D30100060A034030FF, dni: C8D3, endpoint: 01, cluster: 0006, size: 0A, attrId: 4003, encoding: 30, command: 01, value: FF)
dev:40742023-10-15 11:52:52.941 AMtraceinmaster Speed=off
dev:40742023-10-15 11:52:52.938 AMinfoinmaster Switch=0 (off)
dev:40742023-10-15 11:52:52.936 AMtraceinmaster ON_OFF_CLUSTER (cluster:0006 attr:0000 value:00)
dev:40742023-10-15 11:52:52.934 AMdebuginmaster zigbee.getEvent [name:switch, value:off]
dev:40742023-10-15 11:52:52.930 AMdebuginmaster parse(read attr - raw: C8D30100060A00001000, dni: C8D3, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00)
dev:40742023-10-15 11:52:52.606 AMinfoinmaster FW Version=1.04
dev:40742023-10-15 11:52:52.604 AMtraceinmaster BASIC_CLUSTER (cluster:0000 attr:4000 value:1.04)
dev:40742023-10-15 11:52:52.600 AMdebuginmaster parse(read attr - raw: C8D30100001200404204312E3034, dni: C8D3, endpoint: 01, cluster: 0000, size: 12, attrId: 4000, encoding: 42, command: 01, value: 04312E3034)
dev:40742023-10-15 11:52:52.273 AMinfoinmaster FW Date=20230824
dev:40742023-10-15 11:52:52.271 AMtraceinmaster BASIC_CLUSTER (cluster:0000 attr:0006 value:20230824)
dev:40742023-10-15 11:52:52.266 AMdebuginmaster parse(read attr - raw: C8D30100001A060042083230323330383234, dni: C8D3, endpoint: 01, cluster: 0000, size: 1A, attrId: 0006, encoding: 42, command: 01, value: 083230323330383234)
dev:40742023-10-15 11:52:51.959 AMinfoinmaster Model=VZM35-SN
dev:40742023-10-15 11:52:51.956 AMtraceinmaster BASIC_CLUSTER (cluster:0000 attr:0005 value:VZM35-SN)
dev:40742023-10-15 11:52:51.952 AMdebuginmaster There was an error while calling zigbee.getEvent: read attr - raw: C8D30100001A05004208565A4D33352D534E, dni: C8D3, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33352D534E
dev:40742023-10-15 11:52:51.933 AMdebuginmaster parse(read attr - raw: C8D30100001A05004208565A4D33352D534E, dni: C8D3, endpoint: 01, cluster: 0000, size: 1A, attrId: 0005, encoding: 42, command: 01, value: 08565A4D33352D534E)
dev:40742023-10-15 11:52:51.273 AMinfoinmaster Binding Cluster [raw:catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C8D3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[46, 00]]
dev:40742023-10-15 11:52:51.268 AMdebuginmaster parse(catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4600)
dev:40742023-10-15 11:52:50.600 AMinfoinmaster Binding Cluster [raw:catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C8D3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[45, 00]]
dev:40742023-10-15 11:52:50.597 AMdebuginmaster parse(catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4500)
dev:40742023-10-15 11:52:49.934 AMinfoinmaster Binding Cluster [raw:catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C8D3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[44, 00]]
dev:40742023-10-15 11:52:49.930 AMdebuginmaster parse(catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4400)
dev:40742023-10-15 11:52:49.359 AMinfoinmaster Binding Cluster [raw:catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C8D3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[43, 00]]
dev:40742023-10-15 11:52:49.355 AMdebuginmaster parse(catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4300)
dev:40742023-10-15 11:52:49.320 AMtraceinmaster MULTISTATE_OUTPUT_CLUSTER (cluster:0013 data:[90, D3, C8, A2, 73, 19, FE, FF, 27, 87, 04, 8E])
dev:40742023-10-15 11:52:49.311 AMdebuginmaster parse(catchall: 0000 0013 00 00 0040 00 C8D3 00 00 0000 00 00 90D3C8A27319FEFF2787048E)
dev:40742023-10-15 11:52:48.588 AMinfoinmaster Binding Cluster [raw:catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4200, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C8D3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[42, 00]]
dev:40742023-10-15 11:52:48.585 AMdebuginmaster parse(catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4200)
dev:40742023-10-15 11:52:47.920 AMinfoinmaster Binding Cluster [raw:catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4100, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C8D3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[41, 00]]
dev:40742023-10-15 11:52:47.917 AMdebuginmaster parse(catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4100)
dev:40742023-10-15 11:52:47.457 AMinfoinmaster Binding Cluster [raw:catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C8D3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[40, 00]]
dev:40742023-10-15 11:52:47.451 AMdebuginmaster parse(catchall: 0000 8021 00 00 0040 00 C8D3 00 00 0000 00 00 4000)
dev:40742023-10-15 11:52:47.156 AMdebuginmaster configure [zdo bind C8D3 0x01 0x01 0x0006 {048727FFFE1973A2} {}, delay 666, zdo bind C8D3 0x01 0x01 0x0008 {048727FFFE1973A2} {}, delay 666, zdo bind C8D3 0x01 0x01 0x0019 {048727FFFE1973A2} {}, delay 666, zdo bind C8D3 0x01 0x01 0x8021 {048727FFFE1973A2} {}, delay 666, zdo bind C8D3 0x01 0x01 0x8022 {048727FFFE1973A2} {}, delay 666, zdo bind C8D3 0x01 0x01 0xFC31 {048727FFFE1973A2} {}, delay 666, zdo bind C8D3 0x02 0x01 0xFC31 {048727FFFE1973A2} {}, delay 666, he raw 0xC8D3 1 0x01 0x0000 {10 00 00 05 00}, delay 333, he raw 0xC8D3 1 0x01 0x0000 {10 00 00 06 00}, delay 333, he raw 0xC8D3 1 0x01 0x0000 {10 00 00 00 40}, delay 333, he raw 0xC8D3 1 0x01 0x0006 {10 00 00 00 00}, delay 333, he raw 0xC8D3 1 0x01 0x0006 {10 00 00 03 40}, delay 333, he raw 0xC8D3 1 0x01 0x0008 {10 00 00 00 00}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 20 00}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 21 00}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333, he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:40742023-10-15 11:52:47.146 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:40742023-10-15 11:52:47.144 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:40742023-10-15 11:52:47.142 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:40742023-10-15 11:52:47.140 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 01 01}, delay 333]
dev:40742023-10-15 11:52:47.133 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:40742023-10-15 11:52:47.131 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:40742023-10-15 11:52:47.129 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333]
dev:40742023-10-15 11:52:47.127 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 33 00}, delay 333]
dev:40742023-10-15 11:52:47.125 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 21 00}, delay 333]
dev:40742023-10-15 11:52:47.123 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 21 00}, delay 333]
dev:40742023-10-15 11:52:47.121 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 20 00}, delay 333]
dev:40742023-10-15 11:52:47.119 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 20 00}, delay 333]
dev:40742023-10-15 11:52:47.116 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:40742023-10-15 11:52:47.114 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:40742023-10-15 11:52:47.112 AMdebuginmaster getParameter [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333]
dev:40742023-10-15 11:52:47.110 AMdebuginmaster getAttribute [he raw 0xC8D3 1 0x01 0xFC31 {04 2F 12 00 00 15 00}, delay 333]
dev:40742023-10-15 11:52:47.099 AMtraceinmaster readDeviceAttributes()
dev:40742023-10-15 11:52:47.097 AMinfoinmaster Driver Date 2023-10-10
dev:40742023-10-15 11:52:47.093 AMinfoinmaster refresh()
dev:40742023-10-15 11:52:47.090 AMinfoinmaster re-establish lifeline bindings to hub
dev:40742023-10-15 11:52:47.087 AMinfoinmaster configure()
dev:40742023-10-15 11:52:13.580 AMdebuginmaster Debug Logging will be disabled in 60 minutes
dev:40742023-10-15 11:52:13.476 AMinfoinmaster Info Logging will be disabled in 20 minutes
dev:40742023-10-15 11:52:13.474 AMdebuginmaster Debug logging Enabled
dev:40742023-10-15 11:52:13.472 AMtraceinmaster Trace logging Disabled
dev:40742023-10-15 11:52:13.470 AMinfoinmaster Info logging Enabled
dev:40742023-10-15 11:52:13.465 AMdebuginmaster setParameter [he wattr 0x8E0A 0x01 0xFC31 0x0102 0x20 {01} {122F}, delay 333, delay 3000, he raw 0x8E0A 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:40742023-10-15 11:52:13.463 AMdebuginmaster getAttribute [he raw 0x8E0A 1 0x01 0xFC31 {04 2F 12 00 00 02 01}, delay 333]
dev:40742023-10-15 11:52:13.461 AMdebuginmaster setAttribute [he wattr 0x8E0A 0x01 0xFC31 0x0102 0x20 {01} {122F}, delay 333]
dev:40742023-10-15 11:52:13.458 AMdebuginmaster calculateSize(150)
dev:40742023-10-15 11:52:13.428 AMdebuginmaster setParameter [he wattr 0x8E0A 0x01 0xFC31 0x0034 0x20 {00} {122F}, delay 333, delay 3000, he raw 0x8E0A 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:40742023-10-15 11:52:13.426 AMdebuginmaster getAttribute [he raw 0x8E0A 1 0x01 0xFC31 {04 2F 12 00 00 34 00}, delay 333]
dev:40742023-10-15 11:52:13.423 AMdebuginmaster setAttribute [he wattr 0x8E0A 0x01 0xFC31 0x0034 0x20 {00} {122F}, delay 333]
dev:40742023-10-15 11:52:13.421 AMdebuginmaster calculateSize(150)
dev:40742023-10-15 11:52:13.414 AMdebuginmaster setParameter [he wattr 0x8E0A 0x01 0xFC31 0x0016 0x20 {00} {122F}, delay 333, he raw 0x8E0A 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:40742023-10-15 11:52:13.412 AMdebuginmaster getAttribute [he raw 0x8E0A 1 0x01 0xFC31 {04 2F 12 00 00 16 00}, delay 333]
dev:40742023-10-15 11:52:13.408 AMdebuginmaster setAttribute [he wattr 0x8E0A 0x01 0xFC31 0x0016 0x20 {00} {122F}, delay 333]
dev:40742023-10-15 11:52:13.397 AMdebuginmaster calculateSize(150)
