Yes, kind of – there’s actually two different ways to disable local control (remote and local). When you press the button 8x, it disables local control (ie: if you manually press the light switch). However, if you want remote control disabled, that can be done via the device handler in the settings (towards the bottom).
If you go into IDE, can you check to see if they are both showing up as the same, “networkSecurityLevel” (ie: ZWAVE_S0_DOWNGRADE or ZWAVE_S2_FAILED)?
The devices need to have the same networkSecurityLevel to be successfully associated with each other.
I believe @jtronicus brought this up in our thread about improving firmware: On/Off Switch (Red Series) | Project Lights Out (v2.0) - #19 by jtronicus which I think is an awesome idea. So, we’ll definitely look to add this feature and I’ve captured it at the top ![]()
Famous last words lol – I said the same thing about the Dimmer Switch and here we are 6 months late lol.
