I have the LZW31-SN in a 3 way setup with a dumb switch. When my Dumb switch is turned off and I try to turn the lights on from the inovelli dimmer switch, the lights come on for about 10-30 seconds and then turn off. If I flip the dumb switch, itll work normally. I have the settings set up to use 3 way and also say I have a netural. Any advice?
Yeah this has been brought up in a few different threads. What you’re describing is the main issue several of us have experienced. Check this thread
Ahh @Codeman71 thank you glad others are seeing the same issue. I will follow that thread now. From what I see there doesn’t seem to be a resolution yet.
