Association Instructions
@Eric_Inovelli @Alex_Inovelli
The instructions here need to be fixed.
How To: Setting Up Device Associations | Home Assistant Z-Wave JS UI (inovelli.com)
Group 2 should also be associated. That allows the on-off and dimming times to both be used on the associated device.
The parameter 59 no longer exists in zwavejs so explaining how to set that parameter won’t make sense to anyone. It was a bug in zwavejs causing it to show in the first place
It is divided into parameters 59-1 and 59-2.
Agree, the instructions should look more like this for Z-Wave JS: Z-Wave 800 Series 2-1 Switch (On/Off & Dimmer) | Project Phoenix - #507 by rohan
Is this going to get fixed or not because zwaveJS got updated and the association behavior part is completely wrong now???
