Black On/Off switch + Illumin bulb association?
I’ve got a Black On/Off switch that controls a wall outlet.
I have a new Illumin bulb screwed into the lamp that is plugged into that outlet.
I’d like to use Z-Wave association to have the switch control the bulb. I will disable local (and possibly remote) control of the switch if I can get the association working.
I’ve create the association according to [HOW-TO] Using the Z-Wave Association Tool in SmartThings, and disabled local control on the switch but the switch doesn’t do anything.
I have checked the troubleshooting section of that article and verified that both are included with security.
Do I need to use a Red Series (On/Off or Dimmer) for this?
Thanks,
-Tex Clayton
It could be a couple things. Can you post some screenshots of the device data & preferences for the switch? Looks like this:
I cleared the associations and started over today using the instructions at Knowledge Base Redirect – Inovelli
And I’m happy to report that the association now works as expected. The switch is disabled locally (and remotely), but operates the bulb. Now to set up scenes…
