Blue 2-1 antenna performance
@Eric_Inovelli and @EricM_Inovelli is it possible the manufacturer will provide to you and allow you to publish the gain spectrum for the 2.4GHz antenna in the Blue 2-1 switches? If it’s asymmetric it may point towards favored zigbee channels…
@Darwyn_Inovelli - can you publish this?
From the photos in this post, it looks like the antenna is a discrete unit (good) hanging at the end of a piece of coax.
What’s the possibility/ advisability of cracking the housing and pulling the antenna outside, so that it dangles inside the switchbox? Might help some of the signal strength issues if it were isolated from the board a bit more, at least that’s my thought…
Before even trying that, it would seem like the easiest test would be the antenna connector- it’s possible that it isnt properly seated, which would lead to poor performance. How easy is it to get at this connection?
We have someone doing that right now (pulled the antenna out more) and there hasn’t been much of a performance increase (if at all).
Let me see if they want to share the results as they’re volunteering their time and I’m not sure how inundated with requests they want to be lol.
Looks like one confirmed case of a poorly-connected antenna… are these connectors prone to detatchment during shipping, or is it more likely a failure during manufacturing?
I clarified this in the other thread and I’ll do it here as well, to avoid people needlessly taking them apart. Yes, I did gain 10 RSSI, but mid 80’s is still not good, especially 10 feet from the hub. The connector seemed to be seated fine, but since I was in there anyway, I reseated it and moved the antenna wire a little bit. I’m not sure what the solution is going to be, I’m hoping radio power can be adjusted with firmware.
Where is the RSSI shown? I’m using HA with ZHA, and in Device Info → Zigbee info, it shows LQI, but RSSI is “Unknown” for all my Zigbee devices (both the Blue switches and some Sonoff outlets).
FWIW, I was able to pair a switch about 29 feet away through one wall. 32 feet away through two walls didn’t work. And 22 feet away through two walls was borderline.
In Hubitat its on the live zigbee log, each radio command makes an entry.
Seems to have been removed from stand-alone z2m at some point… i put in a feature request to add it back in.
RSSI doesn’t show in ZHA either.
You should be able to see RSSI and LQI both from the device page -
Are you using beta device?
I am, my switches aren’t delivered yet. Just pointing out where to find it in ZHA, if it’s showing unknown that’s going to be different than not being built in so worth noting imo.
My HA box is more of a playground / toy for me, and is a separate piece of hardware. I’m running z2m on a beta Collective Core unit from Oh-La Labs. HA does have access to my devices (through MQTT). Unfortunately z2m isn’t publishing RSSI to MQTT, so HA knows nothing about it. Need a solution from Koen @ company that’s built-in to z2m.
Ah yep, Z2M is going to be a different situation.
Think it might be just that the Sonoff/ TI chip doesn’t show RSSI. Not necessarily HA related.
If that’s the case it’s good to know. I would’ve expected it to be exposed somewhere and in the case of Z2M potentially just needing something changed to send it over mqtt.
Looks like maybe z2m ditched rssi sometime between versions 1.6.18 and 1.7.5:
