Blue 2-1 defaultLevelLocal with dumb switch
I’ve got a three-way setup with a dumb switch. Finding that the default level setting seems to only apply when turned on at the smart switch; when turned on at the dumb switch, the brightness remains at whatever it was set to previously.
Is this known/intended and has anyone found a workaround?
Hey, I noticed no one responded. Is this still the case for you? If so, we can test as a team and see if we are experiencing the same. If so we can get with the engineering team for a fix!
Not a 3-way/dumb setup but this seems similar: Firmware bug: defaultLevelRemote does not work
Still an issue, yes. Will take a look at the other thread to see if it relates. Thanks
