I turned on ALL logging to try to provide additional information regarding this mystery spontaneous OFF-then-ON behavior of MULTIPLE Inovelli Blue switches. This one just happened. Does anyone have a clue has to why these phenomena occur and how to stop it??
dev:422026-12-29 03:52:36.217 PMtrace
Entryway Lights Main Dimmer IB TEMPERATURE_CONFIGURATION_CLUSTER (cluster:0002 data:[82, 00, 00])
dev:422026-12-29 03:52:36.215 PMtrace
Entryway Lights Main Dimmer IB parse(catchall: 0000 0002 00 00 0040 00 9F0F 00 00 0000 00 00 820000)
dev:422026-12-29 03:52:17.474 PMinfo
Entryway Lights Main Dimmer IB Level=254 (100%)
dev:422026-12-29 03:52:17.473 PMtrace
Entryway Lights Main Dimmer IB LEVEL_CONTROL_CLUSTER (cluster:0008 attr:0000 value:FF)
dev:422026-12-29 03:52:17.471 PMdebug
Entryway Lights Main Dimmer IB zigbee.getEvent [name:level, value:100]
dev:422026-12-29 03:52:17.469 PMtrace
Entryway Lights Main Dimmer IB parse(read attr - raw: 9F0F01000808000020FF, dni: 9F0F, endpoint: 01, cluster: 0008, size: 08, attrId: 0000, encoding: 20, command: 0A, value: FF)
dev:422026-12-29 03:52:16.367 PMinfo
Entryway Lights Main Dimmer IB MATCH DESCRIPTOR REQUEST Device:0000 Profile:0104 Cluster:5701
dev:422026-12-29 03:52:16.366 PMtrace
Entryway Lights Main Dimmer IB ON_OFF_CLUSTER (cluster:0006 data:[03, 00, 00, 04, 01, 00, 01, 57, FC])
dev:422026-12-29 03:52:16.364 PMtrace
Entryway Lights Main Dimmer IB parse(catchall: 0000 0006 00 00 0040 00 9F0F 00 00 0000 00 00 0300000401000157FC)
dev:422026-12-29 03:52:15.779 PMinfo
Entryway Lights Main Dimmer IB P33=0 (Overheat: False) [Param:33 Value:0 Default:0]
dev:422026-12-29 03:52:15.777 PMtrace
Entryway Lights Main Dimmer IB Private Cluster (cluster:FC31 attr:0021 value:00)
dev:422026-12-29 03:52:15.775 PMtrace
dev:422026-12-29 03:52:15.773 PMtrace
Entryway Lights Main Dimmer IB parse(read attr - raw: 9F0F01FC310821001000, dni: 9F0F, endpoint: 01, cluster: FC31, size: 08, attrId: 0021, encoding: 10, command: 0A, value: 00)
dev:422026-12-29 03:52:14.436 PMinfo
dev:422026-12-29 03:52:14.435 PMtrace
Entryway Lights Main Dimmer IB ON_OFF_CLUSTER (cluster:0006 data:[02, 00, 00, 04, 01, 00, 01, 57, FC])
dev:422026-12-29 03:52:14.433 PMtrace
Entryway Lights Main Dimmer IB parse(catchall: 0000 0006 00 00 0040 00 9F0F 00 00 0000 00 00 0200000401000157FC)
dev:422026-12-29 03:52:14.099 PMinfo
Entryway Lights Main Dimmer IB Switch=1 (on)
dev:422026-12-29 03:52:14.098 PMtrace
Entryway Lights Main Dimmer IB ON_OFF_CLUSTER (cluster:0006 attr:0000 value:01)
dev:422026-12-29 03:52:14.097 PMdebug
Entryway Lights Main Dimmer IB zigbee.getEvent [name:switch, value:on]
dev:422026-12-29 03:52:14.094 PMtrace
Entryway Lights Main Dimmer IB parse(read attr - raw: 9F0F0100060800001001, dni: 9F0F, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01)
dev:422026-12-29 03:52:12.805 PMinfo
dev:422026-12-29 03:52:12.804 PMtrace
dev:422026-12-29 03:52:12.802 PMdebug
dev:422026-12-29 03:52:12.799 PMtrace
dev:422026-12-29 03:52:12.267 PMinfo
dev:422026-12-29 03:52:12.266 PMtrace
Entryway Lights Main Dimmer IB ON_OFF_CLUSTER (cluster:0006 data:[01, 00, 00, 04, 01, 00, 01, 57, FC])
dev:422026-12-29 03:52:12.264 PMtrace
Entryway Lights Main Dimmer IB parse(catchall: 0000 0006 00 00 0040 00 9F0F 00 00 0000 00 00 0100000401000157FC)
dev:422026-12-29 03:52:11.895 PMinfo
Entryway Lights Main Dimmer IB Dimming Method = Trailing Edge
dev:422026-12-29 03:52:11.894 PMinfo
Entryway Lights Main Dimmer IB P258=0 (Dimmer mode) [Param:258 Value:0 Default:0]
dev:422026-12-29 03:52:11.891 PMtrace
Entryway Lights Main Dimmer IB Private Cluster (cluster:FC31 attr:0102 value:00)
dev:422026-12-29 03:52:11.889 PMtrace
dev:422026-12-29 03:52:11.885 PMtrace
Entryway Lights Main Dimmer IB parse(read attr - raw: 9F0F01FC31100201100034001000, dni: 9F0F, endpoint: 01, cluster: FC31, size: 10, attrId: 0102, encoding: 10, command: 0A, value: 0034001000)
dev:422026-12-29 03:52:11.876 PMinfo
dev:422026-12-29 03:52:11.875 PMtrace
dev:422026-12-29 03:52:11.874 PMdebug
dev:422026-12-29 03:52:11.871 PMtrace
