Blue mmWave losing occupancy while still in room
I installed one of the Blue mmwave dimmers (VZM32-SN) and am using it in Smart Bulb mode to control some Wifi (LIFX) lights. I have an automation setup for simple on/off and presence detection and it works (still lots of work to do here for overrides).
I however have an issue… When sitting on the sofa within the detection zone it loses presence, then if somebody moves occupancy is detected again and the lights turn on (repeats endlessly)… this is not at the edge of the detection zone since when somebody enters\leaves the door behind the sofa it catches this fine. i have validated that the sensitivity is at high (2,) what other params to i need to set or look into?
Thanks for the help and so glad i finally got these! 2 more to install soon.
I had the same issue in my office and my swivel chair, If my back was to the sensor working at one desk it would go to no occupancy. My solution was to add time to this parameter:
  1. mmWave Detection Timeout
I put in 300 seconds because I wouldn’t be idle in that chair position for more that a few minutes. I found it works good for our dining room also but in that case I did 600 seconds just to be safe.
I think this sensor has a very hard time with people sitting on soft things (even at the most sensitive setting). The one I have in our living room is the same as what you described. If I sit on the couch, the sensor eventually loses track of me (usually within a couple minutes or less). If I stand in front of the couch (so only a few inches of difference in terms of distance from the sensor), I can stand very still and the sensor basically never loses track of me. I’ve ended up having to add another mmWave sensor (the Everything Presence Lite) sitting on the media cabinet directly facing the couch to address this. That device doesn’t have the same problem tracking me sitting on the couch.
I’m having the same issue. Sensor works fine if I’m standing at my desk, but when I sit down, it very quickly loses detection and turns off the light. I looked for the setting referenced above, but do not see it listed. I’m using Zigbee2MQTT in home assistant if thats relevant.
I’ve been noticing this to an extent as well. To work around it, I’ve tried adjusting the StayLife parameter, but have found it doesn’t seem to be respected. As a test, I’ve been sitting completely still behind a chair that I know generally blocks my movement. I’ve set the StayLife to something “somewhat” long, e.g. 30,000, which should be 25 minutes according to the documentation in Z2M. However, it still flips to unoccupied after the set HoldTime elapses (which I have set to something short like 10 seconds).
During this time, I’m not moving towards or away from the sensor, simply moving around in the chair and then sitting motionless without getting up, etc. In the visualizer from GitHub - nickduvall921/mmwave_vis: Inovelli mmWave Visualizer for Z2M , I see that it still sees a target and the target is stationary. My understanding of the StayLife from reading the various posts in these forums, was that this should be covered, and as long as it still detects a target, it should wait for the time in StayLife to clear the occupancy.
I have same issue. Installed new Blue dimmer switches in Kitchen, Dining area and Hall; all three areas are in a single open space. Kitchen and Dinning areas occupancy detections are fine. It’s the living room is inconsistent. When somebody is sitting on sofa is living room, it remains “clear”.
I had the same problem sitting on the sofa. I can only surmise that the sofa consistency is about the same as my meat bag consistency, so I blend it as far as the mmWave sensor is concerned. I ended up getting an Everything Presence Pro and set it on the cabinet in front of the sofa. That one seems to be able to track us even when sitting down on the sofa.
