sdbigio
February 13, 2023, 3:14am
21
This Is the switch connected to the load;
@triplee121
This is the one not connected:
Screenshot_20230212_221047_SmartThings|286x1999
I also had the same issue as Eric. I had to unbind, rebind, clear bindings etc a bunch of times to get it to finally stick properly (assuming you are using smartthings?)
@sdbigio awesome! Thank you so much! I am on smartthings. Hoping to give it another shot today or tomorrow.
Thank you so much for this! I did a factory reset and then rebound and that completely solved my problem!
Artfle
April 1, 2023, 3:35pm
24
This solved the problems I was having! THANK YOU!
Specifically, the two settings I needed to mimic to get my 3-way binds to work:
dumb switch in Smart Mode
also, disable “256. Clear Notifications with 2x Config” (default is on)
