Blue Series Smart Presence Sensing Dimmer missing configuration parameters
Just got my Blue Series mmWave dimmer switch and got it easily integrated into Home Assistant; however, I see that there are only a handful of configuration parameters available via Home Assistant:
  • Default move level
  • Firmware
  • On level
  • On/off transition time
  • Start-up behavior
  • Start-up current level
There are many missing that are present on the regular dimmer switch, the AC fan switch, and the on/off switch - e.g., Smart bulb mode, Dimming mode, Local/Remote dimming up/down speed, and many more.
Why aren’t these configuration options available via Home Assistant?
ZHA?
Yes, sorry, ZHA. The 3 models I mentioned all expose these extra configurations, currently.
Just added the custom quirks and things look better. Is there a plan to get these quirks added to main ZHA?
Inovelli has been trying for almost 2 months now :slight_smile: Inovelli - updating support for VZM32 MMwave Presence Sensing Switch by InovelliUSA · Pull Request #4552 · zigpy/zha-device-handlers · GitHub
With the volume of changes in ZHA, it’s not surprising that it takes a while to go through the review process.
Thanks! I sub’d the PR and added my support for it there as well :slight_smile:
