Blue Zigbee 2-1 'powerType' error in Z2M?
Inovelli VZM31SN - fw 2.05 Support by nathanfiscus · Pull Request #4910 · Koenkk/zigbee-herdsman-converters (github.com)
So this is weird on my end, still (running firmware 2.08 and z2m 1.28.4-dev, in docker with image ID d8e7e0d65c2a - that’s latest dev branch as of yesterday). It looks like zigbee2mqtt is messing up when it comes to interpret the values for powerType and others. Looking in the web interface (and in mqtt, via home-assistant) all my powerType fields are Null, despite the switches being installed with a Neutral. When I hit the refresh button next to powerType, the websocket messages show that my browser sends the following:
{"topic":"LTS-BA-1-guest-room-main/get","payload":{"powerType":""}}
and receives the following messages (including logs - each of these JSON objects is a separate websockets message):
{"payload":{"level":"debug","message":"Received MQTT message on 'zigbee2mqtt/LTS-BA-1-guest-room-main/get' with data '{\"powerType\":\"\"}'"},"topic":"bridge/logging"}
{"payload":{"level":"debug","message":"Publishing get 'get' 'powerType' to 'LTS-BA-1-guest-room-main'"},"topic":"bridge/logging"}
{"payload":{"level":"debug","message":"Received Zigbee message from 'LTS-BA-1-guest-room-main', type 'readResponse', cluster 'manuSpecificInovelliVZM31SN', data '{\"powerType\":1}' from endpoint 1 with groupID 0"},"topic":"bridge/logging"}
{"payload":{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":254,"buttonDelay":0,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":254,"defaultLevelRemote":null,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":20,"doubleTapClearNotifications":null,"doubleTapUpForFullBrightness":0,"energy":30.85,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-12-26T21:31:26.644Z","ledColorWhenOff":0,"ledColorWhenOn":null,"ledIntensityWhenOff":1,"ledIntensityWhenOn":0,"linkquality":83,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":"Dimmer","periodicPowerAndEnergyReports":null,"power":500.9,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":1,"remoteProtection":null,"smartBulbMode":null,"state":"ON","stateAfterPowerRestored":null,"switchType":"Single Pole","update":{"installed_version":16908808,"latest_version":16908808,"state":"idle"},"update_available":null},"topic":"LTS-BA-1-guest-room-main"}
{"payload":{"level":"info","message":"MQTT publish: topic 'zigbee2mqtt/LTS-BA-1-guest-room-main', payload '{\"action\":null,\"activeEnergyReports\":null,\"activePowerReports\":null,\"autoTimerOff\":null,\"brightness\":254,\"buttonDelay\":0,\"defaultLed1ColorWhenOff\":null,\"defaultLed1ColorWhenOn\":null,\"defaultLed1IntensityWhenOff\":null,\"defaultLed1IntensityWhenOn\":null,\"defaultLed2ColorWhenOff\":null,\"defaultLed2ColorWhenOn\":null,\"defaultLed2IntensityWhenOff\":null,\"defaultLed2IntensityWhenOn\":null,\"defaultLed3ColorWhenOff\":null,\"defaultLed3ColorWhenOn\":null,\"defaultLed3IntensityWhenOff\":null,\"defaultLed3IntensityWhenOn\":null,\"defaultLed4ColorWhenOff\":null,\"defaultLed4ColorWhenOn\":null,\"defaultLed4IntensityWhenOff\":null,\"defaultLed4IntensityWhenOn\":null,\"defaultLed5ColorWhenOff\":null,\"defaultLed5ColorWhenOn\":null,\"defaultLed5IntensityWhenOff\":null,\"defaultLed5IntensityWhenOn\":null,\"defaultLed6ColorWhenOff\":null,\"defaultLed6ColorWhenOn\":null,\"defaultLed6IntensityWhenOff\":null,\"defaultLed6IntensityWhenOn\":null,\"defaultLed7ColorWhenOff\":null,\"defaultLed7ColorWhenOn\":null,\"defaultLed7IntensityWhenOff\":null,\"defaultLed7IntensityWhenOn\":null,\"defaultLevelLocal\":254,\"defaultLevelRemote\":null,\"dimmingSpeedDownLocal\":null,\"dimmingSpeedDownRemote\":null,\"dimmingSpeedUpLocal\":null,\"dimmingSpeedUpRemote\":20,\"doubleTapClearNotifications\":null,\"doubleTapUpForFullBrightness\":0,\"energy\":30.85,\"firmwareUpdateInProgressIndicator\":null,\"invertSwitch\":null,\"last_seen\":\"2022-12-26T21:31:26.644Z\",\"ledColorWhenOff\":0,\"ledColorWhenOn\":null,\"ledIntensityWhenOff\":1,\"ledIntensityWhenOn\":0,\"linkquality\":83,\"loadLevelIndicatorTimeout\":null,\"localProtection\":null,\"maximumLevel\":null,\"minimumLevel\":null,\"onOffLedMode\":null,\"outputMode\":\"Dimmer\",\"periodicPowerAndEnergyReports\":null,\"power\":500.9,\"powerType\":null,\"rampRateOffToOnLocal\":null,\"rampRateOffToOnRemote\":null,\"rampRateOnToOffLocal\":null,\"rampRateOnToOffRemote\":null,\"relayClick\":1,\"remoteProtection\":null,\"smartBulbMode\":null,\"state\":\"ON\",\"stateAfterPowerRestored\":null,\"switchType\":\"Single Pole\",\"update\":{\"installed_version\":16908808,\"latest_version\":16908808,\"state\":\"idle\"},\"update_available\":null}'"},"topic":"bridge/logging"}
Note the message starting with “action” - the powerType field is unset, but the preceding debug message does say that it received the powerType field back, with the right value. The web interface never updates the powerType field to anything other than “Null”.
Is this an incompatibility issue with the 2.08 firmware again, as in Blue 2-1 + zigbee2mqtt: local changes not reflected in remote state?
I’m seeing similar, my HASS logs are filled with this:
Invalid option for select.garage_switchtype: '1' (valid options: ['Single Pole', '3-Way Dumb Switch', '3-Way Aux Switch'])
Invalid option for select.office_relayclick: 'Disabled' (valid options: ['Disabled (Click Sound On)', 'Enabled (Click Sound Off)'])
Invalid option for select.mudroom_switchtype: '1' (valid options: ['Single Pole', '3-Way Dumb Switch', '3-Way Aux Switch'])
Invalid option for select.mudroom_doubletapupforfullbrightness: '0' (valid options: ['Button Press Event Only', 'Button Press Event + Set Load to 100%'])
Invalid option for select.mudroom_relayclick: '1' (valid options: ['Disabled (Click Sound On)', 'Enabled (Click Sound Off)'])
Was there ever a determination on why this error occurs? I have similar errors in hass log. (41k occurances) where one of the blue’s attributes is throwing an invalid option error. (button delay and doubletapupforfullbrightness for example). Any insight would be appreciated. i’ve been searching for anything on this and this thread is all i can find. Thanks!
I didn’t go digging for the exact cause, but the invalid option error in the logs seemed to me like it was a value that didn’t get migrated when the Z2M converters updated. You should be able to fix these by going into the Z2M interface, selecting the relevant switch, and adjusting the values it’s complaining about manually. Any update will be in the expected range so as soon as that applies it should stop complaining.
Re-selecting the settings did not fix this issue for me.
But when I got looking at it, it was errors on entities that I didn’t really need. For example, the errors posted above by @FuzzyMistborn are entities created by z2m in HA to allow you to configure the initial settings on the device through the entity. The select.garage_switchtype is an input_select entity to change the switch from single pole to 3way either through an HA dashboard or an automation… Beyond the very first time setting this switch up, how often will someone plan to change the switch back and forth between single pole and 3way? Probably never.
The simple solution is to go into HA, search select.garage_switchtype, go under advanced settings for that entity and disable it. No more errors in the logs, and helps clean up some 10,000 entities that z2m automatically creates that we really don’t need to use. And if you do want to change it from single pole to 3 way for some reason, just go into z2m and change it like 99.9% of us would do anyways.
