Can Aux switches dim lights (using Blue series dimmers)?
Sorry is if this is an stupid question. I tried to find a definitive answer (I think it is yes) but I couldn’t actually find one.
I have just installed my first Inovelli blue series switch to control some Hue bulbs. It works great and is exactly what I am looking for. The switch it replaced was a simple single pole Insteon dimmer switch. Now I want to expand my Hue setup and replace some old Insteon switches that are currently controlling some incandescent bulbs in a hallway.
The circuit I am upgrading is a three way circuit. The current set up is two Insteon dimmers that are linked via a scene in my eisy. The traveler wire is capped at both ends. I want to replace the two Insteon switches with two Inovelli switches in Smart Bulb mode. If I use one Smart switch and one Aux switch, will the Aux switch be able to dim the lights, or will it only be able to turn them off and on? I am using the ZHA integration Home Assistant to control the Zigbee devices.
Yes, the Aux switch can dim the light (or rather it instructs the smart dimmer to do the dimming over the wire).
Thank you!
