If you don’t want to mess with the bypasses (I didn’t—), the other alternative is to find a different LED bulb. The Compatible Bulbs for Dimmer Switch (Gen 2) - #47 by amdbuilder thread contains a lot of reports from people on what brand/model bulb worked and whether they required a bypass; I simply replaced my LED bulbs that required bypasses with some GE ones that didn’t. Even adding just one of the GE bulbs fixed it for all the other bulbs on the same load.
