Changing LED bar for notifications in HomeAssistant
Going to post this on the Home Assistant forums tomorrow (I’ve been up way too late working on this), but I made a script blueprint that allows you to pass in all the variables at call-time, rather than at config-time.
The existing issue_all_led_effect requires users to define the device_id at config time, making it difficult to re-use the same color-effect-duration-intensity combo for a different device. The issue_all_led_effect action can also only be called via an automation/script (see the confusion others have had in here about triggering it via directly calling the action versus calling the encompassing automation).
So, I wanted to make a script that a) could be called anywhere, especially in Developer Tools, and b) could have all the variables, including the target device, passed into it as call-time rather than needing to be pre-configured.
And here it is:
# This blueprint will allow you to make one generic script, and pass in all variables, including target switch, effect, colors, etc. on each call.
# Users do NOT need to set up a per-device copy of this script.
blueprint:
  name: Inovelli VZM31-SN Notification LED (ZHA)
  description: >-
    A script that sets the notification LED bar of an Inovelli light switch.
  source_url: https://raw.githubusercontent.com/nwithan8/configs/main/home_assistant/blueprints/scripts/inovelli_vzm31-sn_notification_led_zha.yaml
  domain: script
fields:
  switch:
    description: Which light switch to program
    required: true
    selector:
      device:
        integration: zha
        manufacturer: Inovelli
        model: VZM31-SN
  effect:
    description: Effect to use
    required: true
    selector:
      select:
        options:
          - "Off"
          - "Clear"
          - "Solid"
          - "Fast Blink"
          - "Slow Blink"
          - "Pulse"
          - "Chase"
          - "Open-Close"
          - "Small-Big"
  duration:
    description: How long the effect should last, in seconds (1-254, 255 for indefinite)
    required: true
    selector:
      number:
        min: 1
        max: 255
  level:
    description: How intense the light should be, percentage (0-100)
    required: true
    selector:
      number:
        min: 0
        max: 100
  color:
    description: The color the light should be, (0-254, 255 for white)
    required: true
    selector:
      number:
        min: 0
        max: 255
sequence:
  - choose:
      - conditions:
          - condition: template
            value_template: >
              {{ effect == "Off"}}
        sequence:
          - service: zha.issue_zigbee_cluster_command
            data:
              ieee: >
                {{ (device_attr(switch, "identifiers")|list).0.1 }}
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              command_type: server
              args:
                - 0
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Clear"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 255
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Solid"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 1
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Fast Blink"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 2
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Slow Blink"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 3
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Pulse"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 4
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Chase"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 5
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Open-Close"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 6
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
      - conditions:
            value_template: >
              {{ effect == "Small-Big"}}
        sequence:
            data:
              ieee: >
              endpoint_id: 1
              cluster_id: 64561
              cluster_type: in
              command: 1
              args:
                - 7
                - "{{ color }}"
                - "{{ level }}"
                - "{{ duration }}"
              manufacturer: 4655
mode: single
This blueprint supports all the animations and settings indicated here, and best of all, only needs to be created once.
Since the script has no configuration variables, it’s a generic script that only needs to exist once.
Users can then indicate which switch they want to target with what effect, color, et. al on every call to the script.
